Старый 27.06.2016, 13:34 (12:34)   #241
miazza
miazza Младенец
Nope, you should not remove the SD card when you click on Cancel Documentation. You need to remove the SD card only when RNS-850 reboot normally and show the usual user interface (at the very end of the process).
RNS might reboot several times, just wait until in boots in the user menu (radio menu or phone menu etc...)
To me this did not happen last time.
Afte Cancel documentation it rebooted and restarted to check metafile with download will continue after reboot but it did not reboot, after half an hour it was still black screen.
I inserted the key in the car and the system booted normally .... really strange...
I will try again without removing the SD.
miazza вне форума   Ответить с цитированием Вверх
Старый 27.06.2016, 14:23 (14:23)   #242
bozikakis
Благодарностей: 20
bozikakis Младенец
I did all of the firmware and maps updates with the car turned on. Did you do the same or you just turned on the ignition?
bozikakis вне форума   Ответить с цитированием Вверх
Старый 27.06.2016, 14:36 (13:36)   #243
miazza
miazza Младенец
I updated without engine on and without key inserted.
Simply stareted update in that condition (a friend of mine did the same).
I cannot take the engine on for one hour and more ....
The second time you updated in mnual way and tiked all the voices ... right ?
Старый 27.06.2016, 14:40 (14:40)   #244
bozikakis
Благодарностей: 20
bozikakis Младенец
As I read in many forums, the key must be in car, and at lease the ignition must be on all the time of the process (you don't need to turn on the car, but just leave the ignition on).
When I updated it in manual way, I ticked every option that can be ticked. One by one
Старый 27.06.2016, 14:46 (13:46)   #245
miazza
miazza Младенец
OK. I got the point.
If I take ignition ON, the battery will be drown ... I wil see what I can do .....
Старый 27.06.2016, 14:54 (14:54)   #246
bozikakis
Благодарностей: 20
bozikakis Младенец
That's right. But you can brick your RNS if you do the operations with the ignition OFF.
That is why i did it on the car turned on. The battery is ok then, and there is no worries about to brick the RNS if it suddenly appears with no electricity.
Старый 27.06.2016, 15:01 (14:01)   #247
miazza
miazza Младенец
The brick risk is only during FW upgrade. During Map update you do not have this risk (in worst you end as I am now...).
While upgrading FW I did it with engine on... of course :).
Did you drive during upgrade or siply stop in the garage with engine ON ?
Старый 27.06.2016, 15:24 (15:24)   #248
bozikakis
Благодарностей: 20
bozikakis Младенец
It seems you are right, but anyway I did not want to risk with those upgrades, so I left the engine ON whilst both updates, just to be sure)
I heard that you can drive when you update Maps, but personally me did that on my parking place, I just had some free time to do that.
Старый 27.06.2016, 15:36 (15:36)   #249
nostrum
Аватар для nostrum
Поблагодарил(а): 2,185
Благодарностей: 4,721
If you are not able to update time to leave the engine running, you can connect the charger.
Старый 27.06.2016, 16:01 (15:01)   #250
congo11
congo11 Младенец
The risk of Brick is mainly in one of the last stages of the upgrade, when the V850 chip gets upgraded (MuIOC and MuINIC). One of the last reboots is really slow and the display will be not as bright as normal, do not scare but do not try to reboot or press the buttons on the RNS at that time. If you watch the multimedia unit it will start with all lights on and the fan spinning fast - that is the V850 update. Do not try to reboot the RNS during that part no matter what!
If you are not sure in the car battery then leave the engine running.
If you connect a battery charger then it's not needed the car to be on ignition.
During the update process the multimedia unit cannot be put on sleep.
p.s. There are some cases that the update goes wrong but if you follow these simple instructions this is unlikely to happen.
congo11 вне форума   Ответить с цитированием Вверх
Старый 27.06.2016, 20:18 (22:18)   #251
ghans
Экстремал
Аватар для ghans
Поблагодарил(а): 1,091
Благодарностей: 1,334
The main reason is to control the voltage. The external charger or the working engine are the same but it is good idea not to start the engine during the procedure.
Последний раз редактировалось ghans; 27.06.2016 в 20:20.
Старый 28.06.2016, 00:05 (23:05)   #252
miazza
miazza Младенец
Hello people.
I have a problem.
I deleted the database and tried to install the map.
When I start the update, the system stay for one minute to read the metainfo.txt and after that go on but there is N/A on all the modules ... so no update...
It seems like the device does not find anyhing to update.
I have used the same card I used for the first update and it seems OK at the computer.
What can I do now ?
Is it normal that during the "Delete Database" the Green Menu becomes blocked and need to force reboot ?
Последний раз редактировалось miazza; 28.06.2016 в 09:04.
Старый 28.06.2016, 20:10 (19:10)   #253
miazza
miazza Младенец
Hello people.
I have a problem.
What can I do now ?
Please help me .... I' risking divoce ;)
Тип файла: jpg 20160628_161732.jpg (165.1 Кб, 70 просмотров)
Тип файла: jpg 20160628_161809.jpg (177.5 Кб, 51 просмотров)
Тип файла: jpg 20160628_161826.jpg (195.1 Кб, 51 просмотров)
Тип файла: jpg 20160628_161913.jpg (149.2 Кб, 46 просмотров)
Тип файла: jpg 20160628_161939.jpg (162.8 Кб, 49 просмотров)
Тип файла: jpg 20160628_170240.jpg (182.9 Кб, 47 просмотров)
Старый 28.06.2016, 21:10 (20:10)   #254
miazza
miazza Младенец
This is my situation:
Database info 01/01/70.00:02:30
currently used configuration:
/HBpersistence/navi/db
no valid acios_db found in /database
currently used mapstyle:
/database/map/styles/01/VW526_MapArchive_H_06_01.xar
mapstyle versions:
VW526_MapArchive_H_06_01: 9120 493b0b95
VW526_MapArchive_H_06_02: 9120 493b0b95
VW526_MapArchive_H_06_03: 9120 493b0b95
VW526_MapArchive_H_06_04: 9120 493b0b95
VW526_MapArchive_H_06_07: 9120 493b0b95
VW526_MapArchive_H_06_08: 9120 493b0b95
VW526_MapArchive_H_06_09: 9120 493b0b95
VW526_MapArchive_H_06_10: 9120 493b0b95
VW526_MapArchive_H_06_11: 9120 493b0b95
VW526_MapArchive_H_06_13: 9120 493b0b95
VW526_MapArchive_H_06_14: 9120 493b0b95
VW526_MapArchive_H_06_15: 9120 493b0b95
combistyle versions:
01: 17 4bf4ffee
02: 17 4bf4ffee
04: 17 4bf4ffee
07: 17 4bf4ffee
08: 17 4bf4ffee
09: 17 4bf4ffee
10: 17 4bf4ffee
TMCConfig versions:
TMCConfig: 14 c6fcf21b
content of /database/:
/database/:
total 10
lrwxrwxrwx 1 root root 52 Jan 01 00:00 MMI3G_MapArchive.xar -> /database/map/styles/01/VW526_MapArchive_H_06_01.xar
lrwxrwxrwx 1 root root 37 Jan 01 00:00 SDS.iso -> /mnt/nav/db/pkgdb/SDS3GP/SDS_Data.iso
-rw-rw-rw- 1 root root 783 Jan 01 00:00 clearLastCityHistory.sh
-rw-rw-rw- 1 root root 5 Jan 01 00:00 clearLastCityHistory.sh.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 10 Jan 01 00:00 clearLastCityHistory.sh.SWDL.version.txt
-rw-rw-rw- 1 root root 413 Jan 01 00:00 clearLastCityHistory.xml
-rw-rw-rw- 1 root root 5 Jan 01 00:00 clearLastCityHistory.xml.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 10 Jan 01 00:00 clearLastCityHistory.xml.SWDL.version.txt
lrwxrwxrwx 1 root root 12 Jan 01 00:02 map -> /mnt/nav/map
content of /mnt/nav/map:
/mnt/nav/map:
total 24
drwxr-xr-x 3 root root 4096 Jan 01 00:29 .
drwxrwxr-x 8 root root 4096 Jan 01 00:02 ..
drwxr-xr-x 14 root root 4096 Jan 01 00:31 styles
/mnt/nav/map/styles:
total 112
drwxr-xr-x 14 root root 4096 Jan 01 00:31 .
drwxr-xr-x 3 root root 4096 Jan 01 00:29 ..
drwxr-xr-x 2 root root 4096 Jan 01 00:30 01
drwxr-xr-x 2 root root 4096 Jan 01 00:30 02
drwxr-xr-x 2 root root 4096 Jan 01 00:30 03
drwxr-xr-x 2 root root 4096 Jan 01 00:30 04
drwxr-xr-x 2 root root 4096 Jan 01 00:30 07
drwxr-xr-x 2 root root 4096 Jan 01 00:30 08
drwxr-xr-x 2 root root 4096 Jan 01 00:30 09
drwxr-xr-x 2 root root 4096 Jan 01 00:31 10
drwxr-xr-x 2 root root 4096 Jan 01 00:31 11
drwxr-xr-x 2 root root 4096 Jan 01 00:31 13
drwxr-xr-x 2 root root 4096 Jan 01 00:31 14
drwxr-xr-x 2 root root 4096 Jan 01 00:31 15
/mnt/nav/map/styles/01:
total 13355
drwxr-xr-x 2 root root 4096 Jan 01 00:30 .
drwxr-xr-x 14 root root 4096 Jan 01 00:31 ..
-rw-rw-rw- 1 root root 6828324 Jan 01 00:30 VW526_MapArchive_H_06_01.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_01.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_01.xar.SWDL.version.txt
/mnt/nav/map/styles/02:
total 14174
-rw-rw-rw- 1 root root 7247548 Jan 01 00:30 VW526_MapArchive_H_06_02.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_02.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_02.xar.SWDL.version.txt
/mnt/nav/map/styles/03:
total 13281
-rw-rw-rw- 1 root root 6790168 Jan 01 00:30 VW526_MapArchive_H_06_03.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_03.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_03.xar.SWDL.version.txt
/mnt/nav/map/styles/04:
total 13290
-rw-rw-rw- 1 root root 6795040 Jan 01 00:30 VW526_MapArchive_H_06_04.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_04.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_04.xar.SWDL.version.txt
/mnt/nav/map/styles/07:
total 13208
-rw-rw-rw- 1 root root 6752932 Jan 01 00:30 VW526_MapArchive_H_06_07.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_07.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_07.xar.SWDL.version.txt
/mnt/nav/map/styles/08:
total 13208
-rw-rw-rw- 1 root root 6752932 Jan 01 00:30 VW526_MapArchive_H_06_08.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_08.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_08.xar.SWDL.version.txt
/mnt/nav/map/styles/09:
total 13290
-rw-rw-rw- 1 root root 6795040 Jan 01 00:30 VW526_MapArchive_H_06_09.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_09.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_09.xar.SWDL.version.txt
/mnt/nav/map/styles/10:
total 13290
drwxr-xr-x 2 root root 4096 Jan 01 00:31 .
-rw-rw-rw- 1 root root 6795040 Jan 01 00:30 VW526_MapArchive_H_06_10.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_10.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_10.xar.SWDL.version.txt
/mnt/nav/map/styles/11:
total 13288
-rw-rw-rw- 1 root root 6794052 Jan 01 00:31 VW526_MapArchive_H_06_11.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_11.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_11.xar.SWDL.version.txt
/mnt/nav/map/styles/13:
total 13679
-rw-rw-rw- 1 root root 6994428 Jan 01 00:31 VW526_MapArchive_H_06_13.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_13.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_13.xar.SWDL.version.txt
/mnt/nav/map/styles/14:
total 13355
-rw-rw-rw- 1 root root 6828324 Jan 01 00:31 VW526_MapArchive_H_06_14.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_14.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_14.xar.SWDL.version.txt
/mnt/nav/map/styles/15:
total 13281
-rw-rw-rw- 1 root root 6790168 Jan 01 00:31 VW526_MapArchive_H_06_15.xar
-rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_15.xar.SWDL.compatibility.tx t
-rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_15.xar.SWDL.version.txt
content of /mnt/nav/combi:
/mnt/nav/combi:
total 24
drwxr-xr-x 3 root root 4096 Jan 01 00:00 .
drwxr-xr-x 9 root root 4096 Jan 01 00:00 styles
/mnt/nav/combi/styles:
total 86
drwxr-xr-x 9 root root 4096 Jan 01 00:00 .
drwxr-xr-x 3 root root 4096 Jan 01 00:00 ..
drwxr-xr-x 2 root root 4096 Jan 01 00:00 01
-rw-rw-rw- 1 root root 5 Jan 01 00:00 01.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:00 01.SWDL.version.txt
drwxr-xr-x 2 root root 4096 Jan 01 00:00 02
-rw-rw-rw- 1 root root 5 Jan 01 00:00 02.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:00 02.SWDL.version.txt
drwxr-xr-x 2 root root 4096 Jan 01 00:00 04
-rw-rw-rw- 1 root root 5 Jan 01 00:00 04.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:00 04.SWDL.version.txt
drwxr-xr-x 2 root root 4096 Jan 01 00:00 07
-rw-rw-rw- 1 root root 5 Jan 01 00:00 07.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:00 07.SWDL.version.txt
drwxr-xr-x 2 root root 4096 Jan 01 00:00 08
-rw-rw-rw- 1 root root 5 Jan 01 00:00 08.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:00 08.SWDL.version.txt
drwxr-xr-x 2 root root 4096 Jan 01 00:00 09
-rw-rw-rw- 1 root root 5 Jan 01 00:00 09.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:00 09.SWDL.version.txt
drwxr-xr-x 2 root root 4096 Jan 01 00:00 10
-rw-rw-rw- 1 root root 5 Jan 01 00:00 10.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:00 10.SWDL.version.txt
/mnt/nav/combi/styles/01:
total 598
drwxr-xr-x 2 root root 4096 Jan 01 00:00 .
drwxr-xr-x 9 root root 4096 Jan 01 00:00 ..
-rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp
-rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp
-rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp
-rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp
-rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp
-rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp
-rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp
-rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp
-rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp
-rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp
-rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp
-rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp
-rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp
-rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp
-rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp
-rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp
-rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp
-rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt
-rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp
-rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp
-rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp
-rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp
-rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp
-rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp
-rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp
-rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp
-rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp
-rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp
-rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp
-rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp
-rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp
-rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp
-rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp
-rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp
-rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp
-rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp
/mnt/nav/combi/styles/02:
total 598
/mnt/nav/combi/styles/04:
total 598
/mnt/nav/combi/styles/07:
total 598
/mnt/nav/combi/styles/08:
total 598
/mnt/nav/combi/styles/09:
total 598
/mnt/nav/combi/styles/10:
total 598
content of /mnt/nav/tmc:
/mnt/nav/tmc:
total 33
-rw-rw-rw- 1 root root 5754 Jan 01 00:31 TMCConfig.dat
-rw-rw-rw- 1 root root 5 Jan 01 00:31 TMCConfig.dat.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:31 TMCConfig.dat.SWDL.version.txt
-rw-rw-rw- 1 root root 128 Jan 01 00:31 TMCConfig.dat.sig
-rw-rw-rw- 1 root root 5 Jan 01 00:31 TMCConfig.dat.sig.SWDL.compatibility.txt
-rw-rw-rw- 1 root root 11 Jan 01 00:31 TMCConfig.dat.sig.SWDL.version.txt
Старый 29.06.2016, 15:20 (17:20)   #255
PadAle
Поблагодарил(а): 474
Благодарностей: 272
PadAle СтаршеклассникPadAle СтаршеклассникPadAle СтаршеклассникPadAle СтаршеклассникPadAle СтаршеклассникPadAle СтаршеклассникPadAle Старшеклассник
Может надо завести отдельную ветку для иноязычных пользователей.
Кто захочет, будет там общаеться.
PadAle вне форума   Ответить с цитированием Вверх
Miag67 (29.06.2016)
Старый 29.06.2016, 20:36 (19:36)   #256
miazza
miazza Младенец
Я попытался установить 2014 ПДЧ, но до сих пор нет способа обновления.
Я попытался Nav раздел удалять и:
delNavHDD.sh v2011-11-27
ВНИМАНИЕ: удаление навигационного раздела потребует повторной установки базы данных и части программного обеспечения.
Пожалуйста, нажмите возвращение и сделать этот пункт меню еще раз для подтверждения
Как это работает ? После того, как раздел дель мне нужно будет вставить FW в слот SD и после перезагрузки базы данных нав?
Я надеюсь, что кто-то знает об этом или пытался.
Пожалуйста, помогите мне.
I tried to install 2014 MAP but still no way to upgrade.
I tried Nav partition delete and:
WARNING: deleting the navigation partition will require re-installation of data base and part of the software.
Please press return and do this menu item again to confirm
How does it works ? After partition del I will need to insert FW in SD slot and after reload the nav data base ?
I hope someone knows this or has tried.
Please assist me.
Старый 29.06.2016, 21:13 (20:13)   #257
miazza
miazza Младенец
This is the image
Тип файла: jpg DelNav partition.jpg (138.3 Кб, 53 просмотров)
Старый 30.06.2016, 11:25 (10:25)   #258
s1on
s1on Младенец
прошивка стала без проблем. Делал всё в атомате.
Возникла проблема при копировании карт на сд карту. Пишет что не достаточно места. Флеш новая 32гб от сони. Не хватает 158мб.
Кто сталкивался? как решить?
разобрался. сони устроили нагибалово конкретное флеш на 32 содержит 28.1 Гб.. нашел старую китайскую флешку вней аж 31.2 гб.
поставил копирование.
карты не стали загружатся.
"не удалось проанализировать описание верии
файл:
Строка:1"
Что делать? перезаписывать флешку?
Последний раз редактировалось s1on; 30.06.2016 в 15:16.
s1on вне форума   Ответить с цитированием Вверх
Старый 01.07.2016, 14:34 (13:34)   #259
miazza
miazza Младенец
Short update but still I need help:
1) nav partition deleted
2) tried to reinstall tha MAP but it allowed the reinstall only of the FW part removed by partition del.
3) reinstalled the FW and the following modules have been installed very quickly:
- CombiStyles
- GEMMI
- MapStyles
- KDPreUpdate Check
After this I tried to reinstall the MAP and this time the metainfo.txt has been faster but still full of N/A in all modules except in VW_ECE where I have a "?".
I entered in this module and I foud several subentry with "N":
CTYS3TC_ECE (0)
CTYS3TC2_ECE (0)
LIT3GP_ECE (0)
LIT3GP2_ECE (0)
GDB_ECE
Entering is each of them I can activate the install of:
- Bootloader (this cannot be selected ... I tried)
- Application (this can be selected)
Now my idea is:
- reactivate Green menu (lost during FW reinstall)
- try to delete database (but I am not sure I will be allowed because no data base is installed)
- Try to install manually all the VW_ECE modules (only app)
Finally everythink is now OK ! :)
Тип файла: jpg Applicazione 2.jpg (157.3 Кб, 67 просмотров)
Тип файла: jpg Nav Partition delete.jpg (162.6 Кб, 65 просмотров)
Тип файла: jpg VW_ECE.jpg (154.9 Кб, 56 просмотров)
Тип файла: jpg ECE.jpg (156.4 Кб, 54 просмотров)
Последний раз редактировалось miazza; 03.07.2016 в 18:18.
Старый 03.07.2016, 20:52 (19:52)   #260
Kudenare
Аватар для Kudenare
Kudenare Младенец
Довольно интересно, спасибо)
Kudenare вне форума   Ответить с цитированием Вверх
GAlexandr (21.10.2016)
Текущее время: 18:32. Часовой пояс GMT +3.
