#241 |
Nope, you should not remove the SD card when you click on Cancel Documentation. You need to remove the SD card only when RNS-850 reboot normally and show the usual user interface (at the very end of the process).
RNS might reboot several times, just wait until in boots in the user menu (radio menu or phone menu etc...) Afte Cancel documentation it rebooted and restarted to check metafile with download will continue after reboot but it did not reboot, after half an hour it was still black screen. I inserted the key in the car and the system booted normally .... really strange... I will try again without removing the SD. |
#242 |
Благодарностей: 20
20
To me this did not happen last time.
#243 |
I did all of the firmware and maps updates with the car turned on. Did you do the same or you just turned on the ignition?
Simply stareted update in that condition (a friend of mine did the same). I cannot take the engine on for one hour and more .... The second time you updated in mnual way and tiked all the voices ... right ? |
#244 |
Благодарностей: 20
20
I updated without engine on and without key inserted.
Simply stareted update in that condition (a friend of mine did the same). I cannot take the engine on for one hour and more .... The second time you updated in mnual way and tiked all the voices ... right ? When I updated it in manual way, I ticked every option that can be ticked. One by one |
#245 |
As I read in many forums, the key must be in car, and at lease the ignition must be on all the time of the process (you don't need to turn on the car, but just leave the ignition on).
When I updated it in manual way, I ticked every option that can be ticked. One by one If I take ignition ON, the battery will be drown ... I wil see what I can do ..... |
#246 |
Благодарностей: 20
20
OK. I got the point.
If I take ignition ON, the battery will be drown ... I wil see what I can do ..... That is why i did it on the car turned on. The battery is ok then, and there is no worries about to brick the RNS if it suddenly appears with no electricity. |
#247 |
That's right. But you can brick your RNS if you do the operations with the ignition OFF.
That is why i did it on the car turned on. The battery is ok then, and there is no worries about to brick the RNS if it suddenly appears with no electricity. While upgrading FW I did it with engine on... of course :). Did you drive during upgrade or siply stop in the garage with engine ON ? |
#248 |
Благодарностей: 20
20
The brick risk is only during FW upgrade. During Map update you do not have this risk (in worst you end as I am now...).
While upgrading FW I did it with engine on... of course :). Цитата:
#249 |
Поблагодарил(а): 2,185
Благодарностей: 4,721
5896
#250 |
The risk of Brick is mainly in one of the last stages of the upgrade, when the V850 chip gets upgraded (MuIOC and MuINIC). One of the last reboots is really slow and the display will be not as bright as normal, do not scare but do not try to reboot or press the buttons on the RNS at that time. If you watch the multimedia unit it will start with all lights on and the fan spinning fast - that is the V850 update. Do not try to reboot the RNS during that part no matter what!
If you are not sure in the car battery then leave the engine running. If you connect a battery charger then it's not needed the car to be on ignition. During the update process the multimedia unit cannot be put on sleep. p.s. There are some cases that the update goes wrong but if you follow these simple instructions this is unlikely to happen. |
#251 |
Экстремал
![]() Город: Москва
Поблагодарил(а): 1,091
Благодарностей: 1,334
1809
While upgrading FW I did it with engine on... of course :). Did you drive during upgrade or siply stop in the garage with engine ON ? Оффтопик The main reason is to control the voltage. The external charger or the working engine are the same but it is good idea not to start the engine during the procedure. |
Последний раз редактировалось ghans; 27.06.2016 в 20:20. |
#252 |
Hello people.
I have a problem. I deleted the database and tried to install the map. When I start the update, the system stay for one minute to read the metainfo.txt and after that go on but there is N/A on all the modules ... so no update... It seems like the device does not find anyhing to update. I have used the same card I used for the first update and it seems OK at the computer. What can I do now ? Is it normal that during the "Delete Database" the Green Menu becomes blocked and need to force reboot ? |
Последний раз редактировалось miazza; 28.06.2016 в 09:04. |
#253 |
Hello people.
#254 |
Please help me .... I' risking divoce ;)
Database info 01/01/70.00:02:30 -------------------------------------- currently used configuration: /HBpersistence/navi/db -------------------------------------- no valid acios_db found in /database -------------------------------------- currently used mapstyle: /database/map/styles/01/VW526_MapArchive_H_06_01.xar -------------------------------------- mapstyle versions: VW526_MapArchive_H_06_01: 9120 493b0b95 VW526_MapArchive_H_06_02: 9120 493b0b95 VW526_MapArchive_H_06_03: 9120 493b0b95 VW526_MapArchive_H_06_04: 9120 493b0b95 VW526_MapArchive_H_06_07: 9120 493b0b95 VW526_MapArchive_H_06_08: 9120 493b0b95 VW526_MapArchive_H_06_09: 9120 493b0b95 VW526_MapArchive_H_06_10: 9120 493b0b95 VW526_MapArchive_H_06_11: 9120 493b0b95 VW526_MapArchive_H_06_13: 9120 493b0b95 VW526_MapArchive_H_06_14: 9120 493b0b95 VW526_MapArchive_H_06_15: 9120 493b0b95 -------------------------------------- combistyle versions: 01: 17 4bf4ffee 02: 17 4bf4ffee 04: 17 4bf4ffee 07: 17 4bf4ffee 08: 17 4bf4ffee 09: 17 4bf4ffee 10: 17 4bf4ffee -------------------------------------- TMCConfig versions: TMCConfig: 14 c6fcf21b TMCConfig: 14 c6fcf21b -------------------------------------- content of /database/: /database/: total 10 lrwxrwxrwx 1 root root 52 Jan 01 00:00 MMI3G_MapArchive.xar -> /database/map/styles/01/VW526_MapArchive_H_06_01.xar lrwxrwxrwx 1 root root 37 Jan 01 00:00 SDS.iso -> /mnt/nav/db/pkgdb/SDS3GP/SDS_Data.iso -rw-rw-rw- 1 root root 783 Jan 01 00:00 clearLastCityHistory.sh -rw-rw-rw- 1 root root 5 Jan 01 00:00 clearLastCityHistory.sh.SWDL.compatibility.txt -rw-rw-rw- 1 root root 10 Jan 01 00:00 clearLastCityHistory.sh.SWDL.version.txt -rw-rw-rw- 1 root root 413 Jan 01 00:00 clearLastCityHistory.xml -rw-rw-rw- 1 root root 5 Jan 01 00:00 clearLastCityHistory.xml.SWDL.compatibility.txt -rw-rw-rw- 1 root root 10 Jan 01 00:00 clearLastCityHistory.xml.SWDL.version.txt lrwxrwxrwx 1 root root 12 Jan 01 00:02 map -> /mnt/nav/map -------------------------------------- content of /mnt/nav/map: /mnt/nav/map: total 24 drwxr-xr-x 3 root root 4096 Jan 01 00:29 . drwxrwxr-x 8 root root 4096 Jan 01 00:02 .. drwxr-xr-x 14 root root 4096 Jan 01 00:31 styles /mnt/nav/map/styles: total 112 drwxr-xr-x 14 root root 4096 Jan 01 00:31 . drwxr-xr-x 3 root root 4096 Jan 01 00:29 .. drwxr-xr-x 2 root root 4096 Jan 01 00:30 01 drwxr-xr-x 2 root root 4096 Jan 01 00:30 02 drwxr-xr-x 2 root root 4096 Jan 01 00:30 03 drwxr-xr-x 2 root root 4096 Jan 01 00:30 04 drwxr-xr-x 2 root root 4096 Jan 01 00:30 07 drwxr-xr-x 2 root root 4096 Jan 01 00:30 08 drwxr-xr-x 2 root root 4096 Jan 01 00:30 09 drwxr-xr-x 2 root root 4096 Jan 01 00:31 10 drwxr-xr-x 2 root root 4096 Jan 01 00:31 11 drwxr-xr-x 2 root root 4096 Jan 01 00:31 13 drwxr-xr-x 2 root root 4096 Jan 01 00:31 14 drwxr-xr-x 2 root root 4096 Jan 01 00:31 15 /mnt/nav/map/styles/01: total 13355 drwxr-xr-x 2 root root 4096 Jan 01 00:30 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6828324 Jan 01 00:30 VW526_MapArchive_H_06_01.xar -rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_01.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_01.xar.SWDL.version.txt /mnt/nav/map/styles/02: total 14174 drwxr-xr-x 2 root root 4096 Jan 01 00:30 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 7247548 Jan 01 00:30 VW526_MapArchive_H_06_02.xar -rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_02.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_02.xar.SWDL.version.txt /mnt/nav/map/styles/03: total 13281 drwxr-xr-x 2 root root 4096 Jan 01 00:30 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6790168 Jan 01 00:30 VW526_MapArchive_H_06_03.xar -rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_03.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_03.xar.SWDL.version.txt /mnt/nav/map/styles/04: total 13290 drwxr-xr-x 2 root root 4096 Jan 01 00:30 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6795040 Jan 01 00:30 VW526_MapArchive_H_06_04.xar -rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_04.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_04.xar.SWDL.version.txt /mnt/nav/map/styles/07: total 13208 drwxr-xr-x 2 root root 4096 Jan 01 00:30 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6752932 Jan 01 00:30 VW526_MapArchive_H_06_07.xar -rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_07.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_07.xar.SWDL.version.txt /mnt/nav/map/styles/08: total 13208 drwxr-xr-x 2 root root 4096 Jan 01 00:30 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6752932 Jan 01 00:30 VW526_MapArchive_H_06_08.xar -rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_08.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_08.xar.SWDL.version.txt /mnt/nav/map/styles/09: total 13290 drwxr-xr-x 2 root root 4096 Jan 01 00:30 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6795040 Jan 01 00:30 VW526_MapArchive_H_06_09.xar -rw-rw-rw- 1 root root 5 Jan 01 00:30 VW526_MapArchive_H_06_09.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:30 VW526_MapArchive_H_06_09.xar.SWDL.version.txt /mnt/nav/map/styles/10: total 13290 drwxr-xr-x 2 root root 4096 Jan 01 00:31 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6795040 Jan 01 00:30 VW526_MapArchive_H_06_10.xar -rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_10.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_10.xar.SWDL.version.txt /mnt/nav/map/styles/11: total 13288 drwxr-xr-x 2 root root 4096 Jan 01 00:31 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6794052 Jan 01 00:31 VW526_MapArchive_H_06_11.xar -rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_11.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_11.xar.SWDL.version.txt /mnt/nav/map/styles/13: total 13679 drwxr-xr-x 2 root root 4096 Jan 01 00:31 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6994428 Jan 01 00:31 VW526_MapArchive_H_06_13.xar -rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_13.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_13.xar.SWDL.version.txt /mnt/nav/map/styles/14: total 13355 drwxr-xr-x 2 root root 4096 Jan 01 00:31 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6828324 Jan 01 00:31 VW526_MapArchive_H_06_14.xar -rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_14.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_14.xar.SWDL.version.txt /mnt/nav/map/styles/15: total 13281 drwxr-xr-x 2 root root 4096 Jan 01 00:31 . drwxr-xr-x 14 root root 4096 Jan 01 00:31 .. -rw-rw-rw- 1 root root 6790168 Jan 01 00:31 VW526_MapArchive_H_06_15.xar -rw-rw-rw- 1 root root 5 Jan 01 00:31 VW526_MapArchive_H_06_15.xar.SWDL.compatibility.tx t -rw-rw-rw- 1 root root 13 Jan 01 00:31 VW526_MapArchive_H_06_15.xar.SWDL.version.txt -------------------------------------- content of /mnt/nav/combi: /mnt/nav/combi: total 24 drwxr-xr-x 3 root root 4096 Jan 01 00:00 . drwxrwxr-x 8 root root 4096 Jan 01 00:02 .. drwxr-xr-x 9 root root 4096 Jan 01 00:00 styles /mnt/nav/combi/styles: total 86 drwxr-xr-x 9 root root 4096 Jan 01 00:00 . drwxr-xr-x 3 root root 4096 Jan 01 00:00 .. drwxr-xr-x 2 root root 4096 Jan 01 00:00 01 -rw-rw-rw- 1 root root 5 Jan 01 00:00 01.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:00 01.SWDL.version.txt drwxr-xr-x 2 root root 4096 Jan 01 00:00 02 -rw-rw-rw- 1 root root 5 Jan 01 00:00 02.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:00 02.SWDL.version.txt drwxr-xr-x 2 root root 4096 Jan 01 00:00 04 -rw-rw-rw- 1 root root 5 Jan 01 00:00 04.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:00 04.SWDL.version.txt drwxr-xr-x 2 root root 4096 Jan 01 00:00 07 -rw-rw-rw- 1 root root 5 Jan 01 00:00 07.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:00 07.SWDL.version.txt drwxr-xr-x 2 root root 4096 Jan 01 00:00 08 -rw-rw-rw- 1 root root 5 Jan 01 00:00 08.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:00 08.SWDL.version.txt drwxr-xr-x 2 root root 4096 Jan 01 00:00 09 -rw-rw-rw- 1 root root 5 Jan 01 00:00 09.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:00 09.SWDL.version.txt drwxr-xr-x 2 root root 4096 Jan 01 00:00 10 -rw-rw-rw- 1 root root 5 Jan 01 00:00 10.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:00 10.SWDL.version.txt /mnt/nav/combi/styles/01: total 598 drwxr-xr-x 2 root root 4096 Jan 01 00:00 . drwxr-xr-x 9 root root 4096 Jan 01 00:00 .. -rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp -rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp -rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp -rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp -rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp -rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp -rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp -rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp -rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp -rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp -rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp -rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp -rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp -rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp -rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp -rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp -rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt -rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp -rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp -rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp -rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp -rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp -rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp -rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp -rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp -rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp -rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp -rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp /mnt/nav/combi/styles/02: total 598 drwxr-xr-x 2 root root 4096 Jan 01 00:00 . drwxr-xr-x 9 root root 4096 Jan 01 00:00 .. -rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp -rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp -rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp -rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp -rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp -rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp -rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp -rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp -rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp -rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp -rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp -rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp -rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp -rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp -rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp -rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp -rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt -rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp -rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp -rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp -rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp -rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp -rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp -rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp -rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp -rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp -rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp -rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp /mnt/nav/combi/styles/04: total 598 drwxr-xr-x 2 root root 4096 Jan 01 00:00 . drwxr-xr-x 9 root root 4096 Jan 01 00:00 .. -rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp -rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp -rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp -rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp -rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp -rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp -rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp -rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp -rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp -rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp -rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp -rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp -rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp -rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp -rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp -rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp -rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt -rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp -rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp -rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp -rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp -rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp -rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp -rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp -rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp -rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp -rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp -rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp /mnt/nav/combi/styles/07: total 598 drwxr-xr-x 2 root root 4096 Jan 01 00:00 . drwxr-xr-x 9 root root 4096 Jan 01 00:00 .. -rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp -rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp -rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp -rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp -rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp -rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp -rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp -rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp -rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp -rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp -rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp -rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp -rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp -rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp -rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp -rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp -rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt -rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp -rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp -rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp -rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp -rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp -rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp -rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp -rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp -rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp -rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp -rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp /mnt/nav/combi/styles/08: total 598 drwxr-xr-x 2 root root 4096 Jan 01 00:00 . drwxr-xr-x 9 root root 4096 Jan 01 00:00 .. -rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp -rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp -rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp -rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp -rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp -rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp -rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp -rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp -rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp -rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp -rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp -rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp -rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp -rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp -rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp -rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp -rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt -rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp -rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp -rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp -rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp -rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp -rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp -rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp -rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp -rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp -rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp -rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp /mnt/nav/combi/styles/09: total 598 drwxr-xr-x 2 root root 4096 Jan 01 00:00 . drwxr-xr-x 9 root root 4096 Jan 01 00:00 .. -rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp -rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp -rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp -rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp -rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp -rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp -rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp -rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp -rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp -rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp -rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp -rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp -rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp -rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp -rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp -rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp -rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt -rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp -rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp -rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp -rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp -rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp -rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp -rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp -rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp -rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp -rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp -rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp /mnt/nav/combi/styles/10: total 598 drwxr-xr-x 2 root root 4096 Jan 01 00:00 . drwxr-xr-x 9 root root 4096 Jan 01 00:00 .. -rw-rw-rw- 1 root root 2955 Jan 01 00:00 arr_e.precomp -rw-rw-rw- 1 root root 4870 Jan 01 00:00 arr_ene.precomp -rw-rw-rw- 1 root root 4798 Jan 01 00:00 arr_ese.precomp -rw-rw-rw- 1 root root 6166 Jan 01 00:00 arr_n.precomp -rw-rw-rw- 1 root root 4682 Jan 01 00:00 arr_ne.precomp -rw-rw-rw- 1 root root 5659 Jan 01 00:00 arr_nne.precomp -rw-rw-rw- 1 root root 5431 Jan 01 00:00 arr_nnw.precomp -rw-rw-rw- 1 root root 4929 Jan 01 00:00 arr_nw.precomp -rw-rw-rw- 1 root root 5245 Jan 01 00:00 arr_s.precomp -rw-rw-rw- 1 root root 5209 Jan 01 00:00 arr_se.precomp -rw-rw-rw- 1 root root 4198 Jan 01 00:00 arr_sse.precomp -rw-rw-rw- 1 root root 4054 Jan 01 00:00 arr_ssw.precomp -rw-rw-rw- 1 root root 5248 Jan 01 00:00 arr_sw.precomp -rw-rw-rw- 1 root root 2918 Jan 01 00:00 arr_w.precomp -rw-rw-rw- 1 root root 4874 Jan 01 00:00 arr_wnw.precomp -rw-rw-rw- 1 root root 4923 Jan 01 00:00 arr_wsw.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 destoffroad.precomp -rw-rw-rw- 1 root root 2333 Jan 01 00:00 index.txt -rw-rw-rw- 1 root root 54287 Jan 01 00:00 navglobe_audi.precomp -rw-rw-rw- 1 root root 10503 Jan 01 00:00 neardestination.precomp -rw-rw-rw- 1 root root 9170 Jan 01 00:00 neardestination_e.precomp -rw-rw-rw- 1 root root 9248 Jan 01 00:00 neardestination_s.precomp -rw-rw-rw- 1 root root 9117 Jan 01 00:00 neardestination_w.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 noroute.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offmap.precomp -rw-rw-rw- 1 root root 10757 Jan 01 00:00 offroad.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 offroad_nopic.precomp -rw-rw-rw- 1 root root 10630 Jan 01 00:00 offroadfromleft.precomp -rw-rw-rw- 1 root root 7916 Jan 01 00:00 ra_exit_left.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_left_sidestr.precomp -rw-rw-rw- 1 root root 7921 Jan 01 00:00 ra_exit_right.precomp -rw-rw-rw- 1 root root 9197 Jan 01 00:00 ra_exit_right_sidestr.precomp -rw-rw-rw- 1 root root 5705 Jan 01 00:00 recalc.precomp -rw-rw-rw- 1 root root 9247 Jan 01 00:00 uturn.precomp -rw-rw-rw- 1 root root 8087 Jan 01 00:00 uturnright.precomp -rw-rw-rw- 1 root root 10493 Jan 01 00:00 zielflagge.precomp -------------------------------------- content of /mnt/nav/tmc: /mnt/nav/tmc: total 33 drwxr-xr-x 2 root root 4096 Jan 01 00:31 . drwxrwxr-x 8 root root 4096 Jan 01 00:02 .. -rw-rw-rw- 1 root root 5754 Jan 01 00:31 TMCConfig.dat -rw-rw-rw- 1 root root 5 Jan 01 00:31 TMCConfig.dat.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:31 TMCConfig.dat.SWDL.version.txt -rw-rw-rw- 1 root root 128 Jan 01 00:31 TMCConfig.dat.sig -rw-rw-rw- 1 root root 5 Jan 01 00:31 TMCConfig.dat.sig.SWDL.compatibility.txt -rw-rw-rw- 1 root root 11 Jan 01 00:31 TMCConfig.dat.sig.SWDL.version.txt |
#255 |
Поблагодарил(а): 474
Благодарностей: 272
797
Может надо завести отдельную ветку для иноязычных пользователей.
Кто захочет, будет там общаеться. |
Поблагодарили: | Miag67 (29.06.2016) |
#256 |
Я попытался установить 2014 ПДЧ, но до сих пор нет способа обновления.
Я попытался Nav раздел удалять и: delNavHDD.sh v2011-11-27 ВНИМАНИЕ: удаление навигационного раздела потребует повторной установки базы данных и части программного обеспечения. Пожалуйста, нажмите возвращение и сделать этот пункт меню еще раз для подтверждения Как это работает ? После того, как раздел дель мне нужно будет вставить FW в слот SD и после перезагрузки базы данных нав? Я надеюсь, что кто-то знает об этом или пытался. Пожалуйста, помогите мне. ============= I tried to install 2014 MAP but still no way to upgrade. I tried Nav partition delete and: delNavHDD.sh v2011-11-27 WARNING: deleting the navigation partition will require re-installation of data base and part of the software. Please press return and do this menu item again to confirm How does it works ? After partition del I will need to insert FW in SD slot and after reload the nav data base ? I hope someone knows this or has tried. Please assist me. delNavHDD.sh v2011-11-27 WARNING: deleting the navigation partition will require re-installation of data base and part of the software. Please press return and do this menu item again to confirm |
#258 |
4
прошивка стала без проблем. Делал всё в атомате.
Возникла проблема при копировании карт на сд карту. Пишет что не достаточно места. Флеш новая 32гб от сони. Не хватает 158мб. Кто сталкивался? как решить? ------------------------------------ разобрался. сони устроили нагибалово конкретное флеш на 32 содержит 28.1 Гб.. нашел старую китайскую флешку вней аж 31.2 гб. поставил копирование. ------------------------------------- карты не стали загружатся. "не удалось проанализировать описание верии файл: Строка:1" Что делать? перезаписывать флешку? |
Последний раз редактировалось s1on; 30.06.2016 в 15:16. |
#259 |
Short update but still I need help:
1) nav partition deleted 2) tried to reinstall tha MAP but it allowed the reinstall only of the FW part removed by partition del. 3) reinstalled the FW and the following modules have been installed very quickly: - CombiStyles - GEMMI - MapStyles - KDPreUpdate Check After this I tried to reinstall the MAP and this time the metainfo.txt has been faster but still full of N/A in all modules except in VW_ECE where I have a "?". I entered in this module and I foud several subentry with "N": CTYS3TC_ECE (0) CTYS3TC2_ECE (0) LIT3GP_ECE (0) LIT3GP2_ECE (0) ... ... GDB_ECE Entering is each of them I can activate the install of: - Bootloader (this cannot be selected ... I tried) - Application (this can be selected) Now my idea is: - reactivate Green menu (lost during FW reinstall) - try to delete database (but I am not sure I will be allowed because no data base is installed) - Try to install manually all the VW_ECE modules (only app) Finally everythink is now OK ! :) |
Последний раз редактировалось miazza; 03.07.2016 в 18:18. |
