Старый 15.08.2008, 13:00 (14:00)   #61
extrimal
extrimal Младенец
Тема обсуждалась много раз:
VW Touareg VAG-COM Info
17-Instruments: -- KWP-2000
VAG-COM works fine.
Recoding for chime and warning lamp preferences:
[Select]
[17-Instruments]
[Recode - 07]
Write down the existing 7-digit Soft. Coding for future reference.
Enter the new code from below
[Do It!]
Look at the existing 7-digit Soft. Coding. Look at the fourth digit in the coding. Add the values for the options together to get the correct coding.
0 - No available equipment
+1 - Brakepad wear sensor warning active
+2 - Seatbelt warning active
+4 - Washer fluid level warning active.
Look at the fifth digit in the coding (Market version):
1 - "Europe" (No Navigation system acceptance screen, also see 56-Radio for other changes)2 - "USA" 12 hour clock (Navigation system acceptance screen)
3 - "Canada"
4 - "UK"
Example: If you have all of the above warnings active and your car is set to USA (and your factory Soft. Coding is 0007231), if you would like to remove the seatbelt warning, subtract 2 from the fourth digit to make the coding 0005231. If you would like to keep the seatbelt warning, but remove the Navigation acceptance screen, then change the fifth digit from 2 to 1 to make the coding 0007131. If you'd like to remove both the seatbelt warning and the Navigation acceptance screen subtract 2 from the fourth digit and change the fifth digit from 2 to 1 to make the coding 0005131.
56-Radio: -- KWP-2000
VAG-COM works fine.
Important Note: If you have recoded 17-Instruments from USA to Europe, this changes the way the Radio operates. Note that Europe uses different specs for their radio compared to North America.
FM:
FM frequencies in Europe are spaced .1MHz apart, compared to .2MHz in North America. This causes no problems in using a Nav Plus in North America, it just means you can tune into some frequencies (such as 92.2) which don't exist here. Since it can tune into all the North American FM frequencies that do exist, it works fine.
AM:
AM frequencies in Europe are spaced 9kHz apart, compared to 10kHz in North America. Europe also does not have AM Stereo, so the Nav Plus does not support it. This DOES cause a problem. It means you can only get "close" to some stations when trying to tune them in. It may sound a bit like an AM tuner when you turn the knob just off station, but if you are an AM audiophile, this may be an issue for you. If there is a particular AM station you like to listen to, you can calculate if the Nav Plus will get close in frequency. Simply start at 531kHz, then add 9 kHz until you get close. For example, if you have a favorite station at 660Khz, the closest you can get is 657kHz. The most a station will be out by is 4kHz.
Работы на 5 секунд и в результате на навигации пропадёт экран предупреждения и радио можно будет настраивать с шагом 0,1 мгц, т.е. на все станции.
Удачи
Не хочу показаться дибилом, но по русски можно, а то с радио вопрос жизни!
extrimal вне форума   Ответить с цитированием Вверх
Старый 16.08.2008, 18:12 (19:12)   #62
Буцефал
Бугровский Двукратный
Аватар для Буцефал
Поблагодарил(а): 543
Благодарностей: 1,614
Изображений в галерее: 34
Надо с помощью ВАГ-КОМа по 17 адресу записать код 0007131 и будет тебе счастье.
Старый 18.08.2008, 10:32 (11:32)   #63
Navi
Navi Младенец
По умолчанию Вопрос
Может вот этот диск подойтет http://torrents.ru/forum/viewtopic.php?t=553694
А это точно для RNS2 ??
И с помощью чего сделан этот образ, а то у меня после создания диска РНаС к все равно его не воспринимает.
И еще вопрос как проверить вообще работает ли ДВД привод. (А то у некоторых вставляя в него СD диск с музыкой он воспроизводит а у меня пишет типа Wrong medium) ??
Navi вне форума   Ответить с цитированием Вверх
Старый 21.08.2008, 12:19 (17:19)   #64
Sergey001
Поблагодарил(а): 20
Sergey001 Младенец
Серега нука объясни колхознику что такое VAG-COM и где его взять а я постараюсь найти остальное. ОК?
как колхозник-колхознику :) это устройство такое, для диагностики ВАГовских машин(ауди, VW, шкода итп), оно подключается к компу
Sergey001 вне форума   Ответить с цитированием Вверх
Старый 21.08.2008, 16:41 (17:41)   #65
adv1970
adv1970 Младенец
Печаль
Точно для RNS2 DVD. Только работать он не будет... бесполезно писать на любую болванку. работать будет только оригинальный диск. народ что только не перепробовал. Я штук 20 болванок убил на это дело.
Вот возможные причины:
http://club.cdfreaks.com/f80/vw-tele...europe-177828/
adv1970 вне форума   Ответить с цитированием Вверх
Старый 22.08.2008, 08:36 (09:36)   #66
Navi
Navi Младенец
Ну а у кого нить есть образ ДВД, который при копировании на диск заработал бы НАДО ОЧЕНЬ ПЛИЗ . Да и еще тут говорят что диск для машин 2005 года (RNS 2) отличный от более ранних машин правда нет не знаю (пока ни один еще не заработал )
У меня авто 2005 года
Старый 04.09.2008, 15:38 (15:38)   #67
NIKOLAIBUR
Touareg 3.2 V6 Expedition
NIKOLAIBUR Младенец
Люди помогите найти этот долбаный навигационный диск в Минске. у меня только wma формат читает, и только обычные CD/ ДА И ВООЩЕ БЕЗ НЕГО НЕ ХЕРА НЕ ПАШЕТ.
NIKOLAIBUR вне форума   Ответить с цитированием Вверх
Старый 04.09.2008, 16:16 (17:16)   #68
ILL
Аватар для ILL
Поблагодарил(а): 27
Благодарностей: 76
Изображений в галерее: 19
ILL ПервоклашкаILL Первоклашка
какой "этот" ? диск С ЧЕМ?
ILL вне форума   Ответить с цитированием Вверх
Старый 07.10.2008, 12:04 (12:04)   #69
VAG777
VAG777 Младенец
Приветствую, камрады.
http://rapidshare.com/files/14710394...are.part01.rar
http://rapidshare.com/files/14710435...are.part02.rar
http://rapidshare.com/files/14710434...are.part03.rar
http://rapidshare.com/files/14710435...are.part04.rar
http://rapidshare.com/files/14710435...are.part05.rar
http://rapidshare.com/files/14713467...are.part06.rar
http://rapidshare.com/files/14713645...are.part07.rar
http://rapidshare.com/files/14713652...are.part08.rar
http://rapidshare.com/files/14713657...are.part09.rar
http://rapidshare.com/files/14713659...are.part10.rar
http://rapidshare.com/files/14715453...are.part11.rar
http://rapidshare.com/files/14715637...are.part12.rar
http://rapidshare.com/files/14715651...are.part13.rar
http://rapidshare.com/files/14715657...are.part14.rar
http://rapidshare.com/files/14715665...are.part15.rar
http://rapidshare.com/files/14717485...are.part16.rar
http://rapidshare.com/files/14717673...are.part17.rar
http://rapidshare.com/files/14717672...are.part18.rar
http://rapidshare.com/files/14717690...are.part19.rar
http://rapidshare.com/files/14717705...are.part20.rar
http://rapidshare.com/files/14719542...are.part21.rar
http://rapidshare.com/files/14719752...are.part22.rar
http://rapidshare.com/files/14719778...are.part23.rar
http://rapidshare.com/files/14719802...are.part24.rar
В архиве 4 диска для RNS2:
Blaupunkt Teleatlas Travelpilot DX 2008/09 Deutschland
BeNeLux
Alpen
MajorroadsofEurope
и файл профиля "Teleatlas.ccp".
Пароль для архива: "alphatier".
Я записывал диски с помощью CloneCD на болванки Verbatim, белые. Файл "Teleatlas.ccp" нужно поместить в Slysoft/CloneCD/Profiles и при прожиге выбрать этот профиль!
Рекомендуется использывать резак LG. Я протестировал 2 резака- Samsung и NEC3540. Все диски мой RNS2 смог прочитать с первого раза.
Размер:
Deutschland: 798 MB
BeNeLux: 640 MB
Alpen: 682 MB
Major Roads of Europe: 570 MB
Teleatlas.ccp: 1 KB
Всего: 2,62 GB
VAG777 вне форума   Ответить с цитированием Вверх
Старый 07.10.2008, 13:50 (13:50)   #70
Taylor
Аватар для Taylor
Поблагодарил(а): 1,562
Благодарностей: 1,580
[QUOTE=VAG777;131203]Приветствую, камрады.
[Я записывал диски с помощью CloneCD на болванки Verbatim, белые. Файл "Teleatlas.ccp" нужно поместить в Slysoft/CloneCD/Profiles и при прожиге выбрать этот профиль!
И что ты прочитал? Неужели навигатор фурычит?
Старый 07.10.2008, 14:31 (14:31)   #71
VAG777
VAG777 Младенец
Епстесственно. В тех странах, для которых есть карты.
Старый 14.10.2008, 03:28 (04:28)   #72
eurosat
Аватар для eurosat
eurosat Младенец
Нельзя ли Вас уважаемый попросить куда нибудь отдельно выложить этот волшебный файл профиля
Уже не один раз я пытался скопировать свой ДВд диск а также более новые версии скачивал и пытался зашить разными прогами на разные болванки, всегда получался один и тот же отрицательный результат.
Очень бы хотелось попробовать еще раз с файлом вашего профиля, а качать два гига с рапиды с ума сойдешь, или хотя бы выложите куда нибудь, это все одним файлом , например на торент какой нибудь
eurosat вне форума   Ответить с цитированием Вверх
Старый 14.10.2008, 19:34 (19:34)   #73
Staffgr
Touareg 2.5 R5TDI Individual
Staffgr Младенец
Подскажите, а кто нибуть хотя бы слышал про диск навигации, в котором была бы Беларусь для RNS2?
Staffgr вне форума   Ответить с цитированием Вверх
Старый 21.10.2008, 12:58 (13:58)   #74
GrOV
Аватар для GrOV
GrOV ПервоклашкаGrOV Первоклашка
Ставил на свой старый ТУР с RNS2 CD образ Scandinavia 2008 (TravelPilot) записанный Clone CD с профилем Safe Disk...
По Финке, Норвегии и Швеции вёл без проблем...А по России - либо Дестинатор, либо Garmin в коммуникаторе (HTC Кайзер)
Последний раз редактировалось GrOV; 21.10.2008 в 13:18.
GrOV вне форума   Ответить с цитированием Вверх
Старый 28.10.2008, 19:15 (19:15)   #75
Angel19936
Angel19936 Младенец
Всем привет. А не подскажите, где найти карту минска для Туарега 2006 года???? Заранее всем благодарен!
Angel19936 вне форума   Ответить с цитированием Вверх
Старый 28.10.2008, 19:16 (19:16)   #76
Angel19936
Angel19936 Младенец
Восклицание
Всем привет. А не подскажите, где найти карту минска и Белоруссии для Туарега 2006 года???? Заранее всем благодарен!
Старый 29.10.2008, 09:50 (10:50)   #77
kluchdirekt
kluchdirekt Младенец
По умолчанию 2004 год выпуска
парни, подскажите пожалуйста, ничего не соображаю, только купил. Есть вообще или нет русифицированная навигация на выпуск 2004 года?
kluchdirekt вне форума   Ответить с цитированием Вверх
Старый 29.10.2008, 09:54 (10:54)   #78
kluchdirekt
парни подскажите, только купил TDI R5 2004 г.в., есть навигация русифицированная или нет и если есть где взять?
Старый 29.10.2008, 11:33 (11:33)   #79
Taylor
Аватар для Taylor
Нет и не будет Забудь
Старый 19.03.2009, 12:53 (13:53)   #80
Morda999
Аватар для Morda999
Поблагодарил(а): 35
Благодарностей: 23
Morda999 Младенец
Если у кого есть диск на RNS2 (Скандинавия) скинте пожалуйста образ диска.
Всё что лежит на торренте, не годиться. Образ снят без учёта чтения субканальных данных и поэтому RNS2 его инсталирует, но не читает. Попробовал снимать копию с оригинального (Германия) и всё работает, причём записывал на скорости 40 и всё нормально пашет.
Morda999 вне форума   Ответить с цитированием Вверх
Ivan Olukhov (21.12.2011)
Текущее время: 11:29. Часовой пояс GMT +3.
