Старый 14.01.2020, 18:45 (19:45)   #1
Freeze16
Аватар для Freeze16
Поблагодарил(а): 68
Благодарностей: 234
Freeze16 Ученик младших классовFreeze16 Ученик младших классовFreeze16 Ученик младших классовFreeze16 Ученик младших классов
По умолчанию ошибки по пневме плиз
Wednesday,08,January,2020,15:30:21:01249
VCDS Version: Release 16.8.3 (x64) Running on Windows 7 x64
www.Ross-Tech.com
Address 34: Level Control Labels: 7P0-907-553.clb
Control Module Part Number: 7P0 907 553 J HW: 7P0 907 553 J
Component and/or Version: PASM H01 1030
Software Coding: 14210000
Work Shop Code: WSC 31414 790 00001
ASAM Dataset: EV_PASMConti 001004 (VW52)
ROD: EV_PASMConti.rod
VCID: 3E74F2B3A17354B28E-806A
6 Faults Found:
0784 - Level control system
C10D3 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 114
Reset counter: 4
Mileage: 45824 km
Date: 2077.10.31
Time: 05:45:05
Default: 57
Default: 80
Default: 00
0599 - Pressure Sensor for Ride-Height
C1031 12 [008] - Short to Plus
Freeze Frame:
Fault Priority: 3
Reset counter: 4
Mileage: 46848 km
Date: 2077.12.15
Time: 06:17:01
Default: 7A
Default: AC
Default: 00
0786 - Electical Consumer Cut-Off Active
U1402 00 [008] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 126
Reset counter: 4
Mileage: 48128 km
Date: 2078.03.13
Time: 15:44:61
Default: 00
Default: 9A
Default: 00
0544 - Bleed Valve for Ride-Height
C103B 4B [008] - Over temperature
Freeze Frame:
Fault Priority: 3
Fault Frequency: 115
Reset counter: 4
Mileage: 48384 km
Date: 2078.10.17
Time: 09:45:03
Default: B4
Default: 77
Default: 00
0644 - Level control system
Freeze Frame:
Fault Priority: 5
Reset counter: 4
Mileage: 56832 km
Date: 2078.12.26
Time: 10:05:00
Default: 00
Default: AA
Default: 00
0530 - Valve for Air-Spring Rear Left
C103E 4B [008] - Over temperature
Freeze Frame:
Fault Priority: 1
Fault Frequency: 121
Reset counter: 4
Mileage: 83456 km
Date: 2017.11.29
Time: 19:05:05
Default: BF
Default: 7A
Default: 00
Freeze16 вне форума   Ответить с цитированием Вверх
Старый 14.01.2020, 18:50 (19:50)   #2
ROTEX
Аватар для ROTEX
Поблагодарил(а): 131
Благодарностей: 4,199
Freeze16, описание проблемы будет???
По ошибкам скорее всего конденсат замерз.
Старый 14.01.2020, 19:41 (20:41)   #3
Freeze16
Аватар для Freeze16
Поблагодарил(а): 68
Благодарностей: 234
Машина на морду упавшая. Вроде в теплом гараже стоит говорит чел.
Старый 14.01.2020, 20:07 (21:07)   #4
Shuraley
Поблагодарил(а): 22
Благодарностей: 22
Shuraley Младенец
Вот думал только у меня пробег и дата всегда странная в пневме.
А по ошибкам задний правый клапан.
У меня год назад морда падала, до этого за день как раз на ТО ездил токсин машина была в тепле и потом морозы. Точнее утром была норм, завёл, проехал 20 метров и упала, но нужно было срочно и чуть проехать (4 км) проехал, заглушил/завёл - поднялась и нормально. Далее поехал в сервис обслужить пневму (осушить систему и т.д.) Более не повторялось. Перед этой зимой сразу сделал обслуживание (решил взять за правило делать перед каждой зимой) - не так дорого стоит, зато может помочь избежать проблем и неудобств в эксплуатации.
Shuraley вне форума   Ответить с цитированием Вверх
Старый 14.01.2020, 20:47 (21:47)   #5
ROTEX
Аватар для ROTEX
Freeze16, проверить предохранитель компрессора пневмы, стоит в левом торце торпедо, вверху точно какой не помню, их там всего 2 самых больших на 40 А.
Старый 06.06.2020, 17:14 (18:14)   #6
skvair
Поблагодарил(а): 50
Благодарностей: 166
skvair Первоклашкаskvair Первоклашкаskvair Первоклашка
Сокрубники , и меня постигла проблема
машина стояла с конца февраля без движения, завелась хорошо
Километров через 5 вылезла ошибка "неисправность ходовой в ремонт" но через несколько секунд пропала сама
Потом периодически также приходило раз 5, в основном в движении, один раз продержалась секунд 10-15 на перекрестке потом сама пропала.
Пневма работает , можно перевести в положение и вверх и вниз
Ошибки вот
Подскажите что может быть такое , ощущение что что то не контачит и то работает то нет
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 K HW: 7P0 907 553 K
Component: PASM H01 1110
Revision: 00000000 Serial number: 00000120140595
Coding: 14210000
Shop #: WSC 31414 790 00001
VCID: 3F8DF6FBA67DB57E32-806A
3 Faults Found:
U1402 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 13
Fault Frequency: 232
Reset counter: 1
Mileage: 468224 km
Date: 2061.05.03
Time: 30:08:61
Default: 00
Default: 81
Default: 00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 233
Reset counter: 1
Mileage: 482304 km
Date: 2099.03.20
Time: 29:25:06
Default: DF
Default: 79
Default: 00
Freeze Frame:
Fa qult Status: 00000001
Fault Priority: 6
Reset counter: 1
Mileage: 482560 km
Date: 2099.03.21
Time: 05:53:07
Default: 80
Default: 47
Default: 00
skvair вне форума   Ответить с цитированием Вверх
Текущее время: 23:42. Часовой пояс GMT +3.
