Старый 10.03.2011, 21:57 (21:57)   #1
eXe11eNt
eXe11eNt Младенец
По умолчанию Нужна помощь!ошибки...
Всех приветствую...вобщем продиагностировал сам свой тур!
И тут такое:
Chassis Type: 7L - VW Touareg
Mileage: 223370km/138795miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BF HW:
Component: MOTRONIC ME7.1.1G 6742
Coding: 0000133
Shop #: WSC 03068 444 58831
1 Fault Found:
18308 - Coolant Fan Control 2: Open or Short to Ground
P1900 - 004 - No Signal/Communication - MIL ON
Readiness: 0110 1101
Тут все ясно, его просто нет=)
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
Shop #: WSC 31414 000 00000
Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00576 - Terminal 15
009 - Open or Short to Ground
01049 - Supply Voltage Term 50
009 - Open or Short to Ground - Intermittent
00189 - Control Circuit 2; Relay for Supply Voltage Terminal 50
011 - Open Circuit - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 040 D
Component: CLIMAtronic R/L X 2714
Coding: 0001030
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 D
Component: 02 Airbag 8.4E+ H07 0952
Coding: 0012338
2 Faults Found:
00003 - Control Module
014 - Defective - MIL ON
00595 - Crash Data Stored
000 - - - Intermittent - MIL ON
Тут тоже все ясн...
Address 17: Instruments Labels: 7L6-920-xxx-17-7LA.lbl
Part No: 7L6 920 970 D
Component: KOMBIINSTRUMENT RB4 1735
Coding: 0007231
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
1 Fault Found:
011 - Open Circuit
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 C
Component: SQ HSG 0102
Coding: 0000085
Part No: 7L0 959 701
Component: Tuersteuergeraet FS 0104
Part No: 7L0 959 702
Component: Tuersteuergeraet BF 0104
Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0104
Part No: 7L0 959 704
Component: Tuersteuergeraet HR 0104
1 Fault Found:
011 - Open Circuit
Address 47: Sound System Labels:
Note: Excessive Comm Errors
Address 56: Radio Labels: None
Part No: 7L6 035 180
Component: Radio DE2 0009
Coding: 0000401
Shop #: WSC 00000 000 00000
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
014 - Defective
End ---------------------------------------------------------------------
Основной вопрос как это вылечить?я все расшифровал и перевел, но как решить эти проблемы не знаю...
Добавлено через 6 минут 29 секунд
Есть еще вопрос по поводу фар на GP...
Объясните пожалуйста как работает шторка ксенона с механическим открытием?
Тоесть смотришь в фару и видишь 2 контакта на шторке... тут все ясно, а есть еще фары без клеммы а с хер**й типа самореза, берешь отвертку, крутишь и шторка открывается и закрывается...как работает именно такая фара?
Последний раз редактировалось eXe11eNt; 10.03.2011 в 21:57. Причина: Добавлено сообщение
eXe11eNt вне форума   Ответить с цитированием Вверх
Старый 10.03.2011, 22:12 (23:12)   #2
Werkstatt
Инженер
Аватар для Werkstatt
Поблагодарил(а): 45,012
Благодарностей: 38,831
А это ошибки сейчас стёрты? Вновь не выявились? Если нет, то вопросов не должо быть к автомобилю. При падении напряжения АКБ бывает такое, что в блоки записываются различные ошибки. При их стирании, ошибки удаляются и больше не проявляются.
Старый 11.03.2011, 09:22 (09:22)   #3
eXe11eNt
eXe11eNt Младенец
Да все стирал...все-равно не пропали. В добавок на приборке горит значек двигателя и обороты стали плавать 650-700.
ПС все катушки новые.
Старый 11.03.2011, 09:38 (10:38)   #4
Werkstatt
Инженер
Тут нужно разбираться непосредственно с автомобилем. После чего ошибки-то возникли? Есть на то какие-то обстоятельства? Машина после ДТП? Я бы рекомендовал обратиться на сервис.
Старый 11.03.2011, 10:23 (10:23)   #5
eXe11eNt
eXe11eNt Младенец
Был у дилера.По плавающим оборотам сказали лямда-зонд и катушки.Его я поменял и поменял катушки.Машина поработала 2 часа хорошо, я удалил ошибки.И вот после удаления ошибок снова началось плавание...и появились вышеизложенные ошибки...их до этого не было.
Еще не могу понять...печка работает нормально... включаю заднюю передачу и она начинает издавать неприятный звук всасывания на порядок выше чем в обычном режиме...так и должно быть ?
Добавлено через 7 минут 48 секунд
До дилера были эти ошибки:
Coding: 0000133
19 Faults Found:
16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
P0160 - 004 - No Signal/Communication - MIL ON
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 002 - Lower Limit Exceeded - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - Intermittent
16690 - Cylinder 6: Misfire Detected
P0306 - 001 - Upper Limit Exceeded - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 001 - Upper Limit Exceeded - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 008 - Implausible Signal - Intermittent
18033 - Powertrain Data Bus: Implausible Message from TCU
P1625 - 008 - Implausible Signal - Intermittent
18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
P1628 - 008 - Implausible Signal - Intermittent
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 002 - Lower Limit Exceeded - Intermittent
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 008 - Implausible Signal - Intermittent
18053 - Powertrain Data Bus: Missing Message from AWD Controller
P1645 - 008 - Implausible Signal - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal - Intermittent
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 008 - Implausible Signal - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0110 1001
Последний раз редактировалось eXe11eNt; 11.03.2011 в 10:23. Причина: Добавлено сообщение
Старый 11.03.2011, 11:15 (12:15)   #6
Алексей174
Причина: 4.4.15
Поблагодарил(а): 2,056
Благодарностей: 1,884
Алексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курсАлексей174 Второй курс
При включении задней, система вентиляции автоматически переключается на обдув стекол
Алексей174 вне форума   Ответить с цитированием Вверх
Старый 11.03.2011, 12:29 (13:29)   #7
Werkstatt
Инженер
А на той станции, где делали ремонт, как объясняют это всё?
Старый 11.03.2011, 15:24 (15:24)   #8
eXe11eNt
eXe11eNt Младенец
Теперь ясно, но почему всасывает а не выдувает?
Добавлено через 4 минуты 53 секунды
Ремонт делал сам в своем сервисе.
Поэтому и пишу сюда.
Меня больше волнуют обороты...что еще проверить кроме Л-зондов , катушек и свечей?
Последний раз редактировалось eXe11eNt; 11.03.2011 в 15:24. Причина: Добавлено сообщение
Старый 11.03.2011, 21:58 (00:58)   #9
triada13
Благодарностей: 160
triada13 Первоклашкаtriada13 Первоклашкаtriada13 Первоклашка
eXe11eNt, пробег какой?
Coding: 0001030
1 Fault Found:
Отсоединен датчик качества воздуха.
triada13 вне форума   Ответить с цитированием Вверх
Старый 11.03.2011, 22:00 (22:00)   #10
Робот
Дружественный информатор
Администрация клуба
Аватар для Робот
Благодарностей: 32
Робот Детский сад
По умолчанию Уведомление
Эта тема была перенесена из раздела → Touareg и Touareg GP.
Перенес: Жан Тодт
Правила форума | Руководство форума | Обратная связь | Список модераторов
Робот вне форума   Ответить с цитированием Вверх
Старый 11.03.2011, 23:23 (23:23)   #11
eXe11eNt
eXe11eNt Младенец
Coding: 0001030
1 Fault Found:
Где его искать?
Пробег 223 тыс.
Старый 12.03.2011, 00:11 (01:11)   #12
mikas_allroad
Аватар для mikas_allroad
Поблагодарил(а): 478
Благодарностей: 793
Изображений в галерее: 93
Не на обдув стекол, а на режим рециркуляции, дабы при движении задним ходом выхлопные газы не засасывались в систему отопления\конциционирования.
Добавлено через 2 минуты 54 секунды
Где его искать?
Пробег 223 тыс.
датчик прекреплен к пластиковому кожуху закрывающий трапецию стеклоочестителей (между капотом и лоб. стеклом), кстати у меня когда меняли стекло, снимали этот кожух и при установки забыли одеть штекер на датчик, два года думал, что датчик нужен новый, оказлось все банально просто.
Последний раз редактировалось mikas_allroad; 12.03.2011 в 00:11. Причина: Добавлено сообщение
Алексей174 (12.03.2011)
Старый 12.03.2011, 00:25 (01:25)   #13
Алексей174
Причина: 4.4.15
Абсолютно прав,
Старый 12.03.2011, 00:45 (01:45)   #14
Werkstatt
Инженер
С автомобилем разбираться нужно. Проводку проверять на предмет правильности тока электрических импульсов. И в связи с чем возникают ошибки по стеклопдъёмникам, катушкам и т. д. Может, имеет смысл отправить запрос черз DISS у дилера?
Старый 12.03.2011, 09:43 (12:43)   #15
triada13
Благодарностей: 160
А может банально топлива нехватает, неплохо было бы посмотреть насосы в баке и их внутренние сетки, пробег то большой.
Старый 12.03.2011, 15:04 (16:04)   #16
Werkstatt
Инженер
Да там целая тусовка из ошибок: по щитку, по шине данных, по климатронику, по блокам управления дверьми, по блоку KESSY, по аирбэгу. А теперь выясняется, что ещё и по расходомеру и по смесеобразованию в каждом цилиндре. Нужно брать живой автомобиль и разбираться непосредственно с конкретными неисправностями по машине. Провести ведомую диагностику, для начала, надо бы.
Старый 12.03.2011, 16:55 (19:55)   #17
triada13
Благодарностей: 160
Werkstatt, может еще глянуть жгут проводов в районе упора под левую ногу водителя, вечно там скрутки гниют.
Старый 12.03.2011, 18:35 (23:35)   #18
Junstar
Аватар для Junstar
Junstar Младенец
Триада, а с этого места поподробнее можно? Как туда заглянуть? У меня проблемка небольшая, левый передний габарит не горит.Лампочку поменял не помогло, предохранители оба целые. На разъем фары + подаешь, все горит. Напряжение не подается с жгута на разъем блок-фары, не хотелось по такой мелочи "официалов" беспокоить, накладно как то Они ведь могут и проводку целиком поменять предложить
Junstar вне форума   Ответить с цитированием Вверх
Старый 12.03.2011, 19:05 (22:05)   #19
triada13
Благодарностей: 160
Junstar, если даш данные авто скину тебе схему для него. анасчет тех проводов, они к освещению не относятся. Тебе желательно провод от блока бортовой сети до разъема фары вызвонить.
Последний раз редактировалось triada13; 12.03.2011 в 19:07.
Старый 13.03.2011, 20:17 (20:17)   #20
eXe11eNt
eXe11eNt Младенец
Всем спасибо за помощь!
Завел этим утром, работать стал ровно...
Но горит значек двигателя и EPC
И забыл спросить про странный звук при нажатии педали газа стало слышно как какой-то клапан под капотом всасывает воздух ...т.е Жму педаль, звук всасывания, потом обороты растут...что это может быть?Должно быть так или должно быть незаметным?
Текущее время: 07:54. Часовой пояс GMT +3.
